Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 17 1:08 pm)
I've done some experimenting with pistons in the past. What worked best (trick derived from the book 'Secrets of figure creation with Poser 5' by B.L. Render) is making the piston a body part, and use "point at" another body part (usually a bone without geometry, positioned so that the piston direction is exactly right).
Whatever the body part movements, the piston will move and point in exactly the right direction. No ERC needed.
I can HIGHLY recommend that book. ISBN is 0-240-51929-9
An exact amount, well, it would need some calculations. But yes, it can be done.
If you want to move the piston up by a different amount than moving it down: yes, that can be done too. You'll have to use two "intermediate" valueParms, set their min/max limits to 0 and 1, and -1 and 0 respectively, slave those valueParms to your master dial(s), and slave the actual movement parameters of the piston to the intermediate dials, at different "deltaAddDelta" values.
Moving one piston up while the other moves down: slave both movement parameters to a master dial, one at detlaAddDelta=1, one at deltaAddDelta=-1.
If you want to work purely in Poser 7, of course, you can do it very simply.
My python page
My ShareCG freebies
If you want to know about ERC, again, I really recommend that book I mentioned. It's far more than a cookbook, it explains HOW things work, so that you can appy the knowledge to your own situation. Definitely the best 50 euros I ever spent on Poser material.
nerd3D also has a pretty good explanation on how it works (he calls it "superconforming") on his site, www.nerd3d.com
CR2Builder by kim99 is a handy free tool for creating ERC channels. While you still have to do a few things by hand, it'll do the bulk of the "typing" for you.
Whenever I do ERC work, I use CR2Builder. You can find it here
Caveat: CR2Builder can NOT handle Poser files that have been involved in dynamic cloth or hair calculations.
Q: If I have a figure with two pistons for example, and they are each seperate groups, can ERC be used to animate them so that one piston raises as the other one lowers? If yes then how is it done? A: Yes! It's quite easy. There are a couple of ways you could do it. Let's say for example that the 'yTran' dial moves the pistons up and down, and that the actor number used in the figure is ":1". Place this valueParm channel in the figures 'BODY' actor:
valueParm Pistons
name Pistons
initValue 0
hidden 0
forceLimits 0
min -100000
max 100000
trackingScale 0.004
keys
static 0
k 0 0
interpStyleLocked 0
Let's say the first piston is named "piston_1:1". Find the 'translateY' channel in "piston_1:1". Next find the the line in that cahnnel that says "interpStyleLocked", under that line paste the following slaving code: valueOpDeltaAdd Figure 1 BODY:1 Pistons deltaAddDelta 1.000000
Now find the 'translateY' channel in in the second pistin "piston_2:1". Paste in this code: valueOpDeltaAdd Figure 1 BODY:1 Pistons deltaAddDelta 1.000000
The only diffrence is the "-" in the 'deltaAddDelta' line. Now turnind the "Pistons" dial in the Body actor should make the pistons move in opposite directions. To explain the slaving code: Figure 1 = the figure number BODY:1 = the actor where the master channel lives Pistons = the name of the master channel deltaAddDelta 1.000000 = the control ratio, you can change this number to make the slave channels responde more or less strongly to the dial of the master channel. I said there are a couple of ways to do it. Another way would be to directly slave the translateY channel in "piston_2:1" to the translateY channel in "piston_1:1", using a minus sign in the deltaAddDelta line: valueOpDeltaAdd Figure 1 piston_1:1 Pistons deltaAddDelta -1.000000
You would then move both pistons by moving "piston_1:1".
Q: The other question is can ERC be made so that the object moves a certain amount, for example, if I want the piston to raise 3 in y trans can that be done and can decimal numbers be used and if it can be done then how do I do it? A: I think I know what you are asking, but I may have misunderstood. You can limit the movement in the master channel by forcing the limits, to set a maximum value for the dial of "3.5" and a minimum of "-1.2" you would edit the channel like so:
valueParm Pistons
name Pistons
initValue 0
hidden 0
forceLimits
min
max
trackingScale 0.004
keys
static 0
k 0 0
interpStyleLocked 0
These values refer to Poser Units, the values displayed on the dials may be diffrent if Poser is not set to dislplay measurements in Poser Units. Limits forced in a slave channel will be ignored when the slave is being controled via a master channel. The 'trackingScale' line determins the minimum increment that the dial can change by.
Q: Can an object like a piston be made to move up a certain amount and to move back down a certain different amount? For example moving up in y 5 and down 3? A: There may be a way to do this with ERC, but I don't know how. You could record the movement as an animated pose, I think that's how I would do it. Also you can incorporate an animated pose into a cr2, let me know if you want details of how to incorporate an animated pose into a cr2. In P7 only, you could use 'dependent parameters' see Ockham's "Tutorial for new 'dependent parameters' in p7": http://www.3dcommune.com/3d/forum.mv?Poser+read+8830039578 ...Or use his Python script linked in his post above.
