Bryce F.A.Q (Last Updated: 2024 Nov 12 7:03 am)
ctrl+mouse click will let you choose an individual item, then manipulate (either drag, or go to the Edit window and use the controls). Bryce tends to 1) make anything created 1 Bryce unit in size, and 2) drop them all initially in the same place. Hope that helps.
I find it easiest to use ctrl click to select the item I want, then I go into top view to move it to the front.
Measure
your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
I actually DID try to find this in Bryce help first, but maybe I couldn't see the forest for the trees. I would like to know how to move an object to the front. Sometimes I place several things in the picture, then decide to put one more thing, but it ends up hidden BEHIND another object. How do I pull it to the front?
Thank you for your help. (:
Carol aka Sassy
If you can't stand the heat,
Don't tickle the dragon!
