Sat, Jan 25, 9:02 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 25 6:57 pm)
Subject: Preview Pane Locks Up in Poser7
lwperkins ( ) posted Mon, 12 February 2007 at 8:20 PM · edited Wed, 22 January 2025 at 8:58 AM
Is anyone else having this problem? I had a clean install of Poser 7 (full) on a brand new pc running WindowsXP, and I can load figures fine, it's just after moving the figure around for about 7 or so moves (lift arm, rotate head, move leg, adjust fingers)..whoops, the image is frozen. If I shift the view to two panes, the same thing goes on--the second pane will work for a bit, then freeze too. The outer UI still works fine. I thought maybe this was a preference problem, because I read on the e-fronteir site that strange behavior is caused by corrupted preferences, and the problems showed up after I switched to "Launch to previous state". Things didn't clear up when I switched back to "Launch to factory state", nor did turning the number of undos from 100 to 6 help (I thought maybe the cache was filling sucking up the memory (I have 1024 meg of RAM, so I hoped not). I wrote to e-frontier but I have not heard back from them, and it's been a week. I looked in my Prefs folder and it has the following contents: two folders with English and Sketch Prefs. Is that what should be in there? I'm about ready to reinstall it, though I hate to since it's such a long install.
thx, Lynn
svdl ( ) posted Mon, 12 February 2007 at 8:52 PM
It could be OpenGL settings. Updating to the latest graphics card drivers might help.
If that doesn't work, you might try switching to SreeD, or turn down the OpenGL quality options.
My gallery   My freestuff
pjz99 ( ) posted Mon, 12 February 2007 at 8:56 PM
Does this happen with every figure?
Does this happen with untextured view?
Does this happen with wireframe view?
My Freebies
lwperkins ( ) posted Mon, 12 February 2007 at 8:59 PM
The open gl settings hadn't occured to me at all--I'll have to give that a try tomorrow. I would think the drivers would be up to date since it's a brand-new setup, but I'm no expert. Thanks for the tip--at least I can give it a try and even if it doesn't work that is another thing to check off. I appreciate your help!
--Lynn
lwperkins ( ) posted Mon, 12 February 2007 at 9:02 PM
pjz99: Yes, it does it with Miki, Sydney and Simon, and in wireframe, smooth shaded, hidden line--I was looking for workarounds. No dice:-(
pjz99 ( ) posted Mon, 12 February 2007 at 10:22 PM
It's probably better to try installing freshly downloaded video drivers - what is installed on a "brand new" PC could have been configured packaged many months ago.
My Freebies
lwperkins ( ) posted Tue, 13 February 2007 at 5:45 AM
This is true, and it's a lot easier to download new drivers than some of the other fixes;-) Thank you! I'll post a new thread if that fixes it--I can't do it today (too much work) but hopefully this weekend I can tinker with it.
Thew ( ) posted Tue, 13 February 2007 at 12:26 PM
I had this exact issue and updating the video drivers was suggested by ef support and did the trick.
lwperkins ( ) posted Tue, 13 February 2007 at 1:43 PM
Now I have hope;-) Thanks, Thew!
lwperkins ( ) posted Fri, 16 February 2007 at 11:36 AM
Just wanted to let everyone know that downloading the nVidia drivers seems to have fixed the problem (fingers crossed). I'm so grateful for the hints! I certainly would not have thought of it on my own!
