Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 7:49 pm)
One way is to start with a baked normals map, and a map of the wire mesh. The baked normals map with the wire mesh map as an overlay provides a nice way of painting a color map, or merging several photographs as a color map, using skin resources and a painting application, etc. It better shows you where the areas you are texturing lie, which means fewer trips from photoshop, Z-brush, etc to the application you use to render your model. I like to create the displacement, or bump map first in Z-brush and photoshop, and use it in concert with the normal and wire mesh maps.
This is how I do it anyway, but be aware I'm no expert.
Robert Undi's method is a better, more difficult way, and may be found in 3D Artist issues 41-43. Essentially you create a turntable for your camera, place a chair for the model to sit on at its center, and take fifteen photographs from position 1 at 0 degrees (the front view) to position 15 at 90 degrees (the side view). You may do this with the model standing up too, add more frames until you have gone a full 360 degrees around the model.
In photoshop load your 3d models template, and the photographs; place the photographs so that they overlap each other. After removing shadows in certain areas, and blending the photographs where their edges overlap/meet in photshop you achieve an end result, which looks as though you unwrapped a human. Now you can adjust the map using something like surface suite pro in 3ds max, or photoshop so that it fits your 3d models uv map properly.
The example of an unwrapped baked normals map is from a 3d.sk tutorial.
You can find some images in my gallery:
http://www.renderosity.com/mod/gallery/index.php?image_id=1262527&member
http://www.renderosity.com/mod/gallery/index.php?image_id=1100639&member
On this images you can see how you do it.Hope it will be helpful for you
Snow Sultan's templates are a must ... and my favorite tutorial is by btsculptor here in the MP. The Volume 3 is for unimesh characters and gives a good, solid base to expand from. I recommend it to anyone who wants to learn how to do photo-realistic skin textures.
Hugz from Phoenix, USA
Victoria
You should also check this thread:
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2685101
there is link in there to a terrific tutoturial how to make a skin without any pictures: I think it's a must-read for any skintexturemaker.
regards,
Thijs
"*Curious if anyone knows how many megapixals is necessary to get decent resolution on digital photos for textures. ATM I have access to a 5.0 and 8.0 I think - that enough or do we need to splurge for yet another camera?"
*That rather depends on just how detailed you want your resulting texture to be.
Consider:
A 1024x1024 image is just over 1 mega-pixels in size.
A 4000x4000 image takes up 16 Megs.
However, you're probably not going to need 4000x4000 unless you're going for extreme close-up, and anyway the result will be distorted as it gets stretched/squished when applied to the texture.
Use smaller photos, and clone bits over the texture instead (you can clone parts of the original texture in different places on the texture - no-one will ever notice..)
And if you're not doing extreme close-ups, then you don't really need to go down to "pore-level", the detail will be lost in the rendering/anti-aliasing.
The BIG thing to remember is: DON'T USE JPG if the camera has options to save in lossless format (tiff, png etc.). As soon as you save in jpg, detail is lost...
So even your 5.0-meg camera should be good for a few textures at 1000x1000...
Cheers,
Diolma
While browsing the whats new selection in the marketplace I came across a package of reference material (which is a bunch of up close photos of areas of the body) - and I wondered if anyone could explain exactly what you do with photo references. Are they the same thing as merchant resources?
Do you copy - or cut an paste it onto a blank V3 template? I'd like to start creating my own textures - but I just don't know where to start.
Just enjoying the Vue. :0)
