Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 2:22 am)
*The major scene stealer in the film will require a completely 3D Manhattan, NY model.
What is a 3d Manhattan??? Are you saying Streets or apartments, neighborhood...
are you saying a 3D model of the Manhattan Island it self...! as in an aerial view...?
are you offering money for undertaking such a project..?
I'd suggest you check out Google Earth. It has some fairly elaborate 3-D models of real locations. I don't have it installed, though, so I can't check on lower Manhattan.
You can't export geometry directly from Google Earth, but there is a hack you can use to get geometry out of it into a format Poser can use. It's called Ogle and it can 'snatch" the meshes from any app that uses OpenGL as its rendering engine (as Google Earth does.)
Guess that means it won't work in Vista, though. Good luck
Google earth shows satellite pictures of the entire planet not 3d models.... I got it... unless you're speaking of another section or program... Maybe they have on their site 3d models I have never seen...
Yeah Google Earth is perfect for previz, and I could also use it as a blueprint to set up a higher detailed model. I'm going to check out Ogle and see what I can do. I already visited the page and it looks way beyond me (I'm not good with coding), so I'm still open to more suggestions if there are any alternatives... but for now I'll see what I can do. Thanks for the help to everyone!
My understanding is that you don't need to do any coding to use Ogle. You do need to hand edit some configuration files (ini files) but that's not the same as writing code or scripting. And maybe not even that (see step 7 below.)
You do need to d/l and install another app called GLIntercept that Ogle uses to grab the scene. These two apps run while you are viewing a 3-D scene in a third app like Google Earth.
The instructions are as follows:
.bin``.
distribution, not the src
).OGLE.dll
file) into the Plugins
directory for your GLIntercept installation, typicallyC:Program FilesGLIntercept0_5Plugins
, and rename the directory to OGLE``ogle_*
to OGLE
). (i.e. change the name fromLogPerFrame::FrameStartKeys
variable. (This is one of the settings in the GLConfig.ini file you have to edit. The GUI probably lets you set this also.).obj
file in the directory where your application runs. Open it in...POSER of course!
The above is my "lite" version of the instructions found on this page:
http://ogle.eyebeamresearch.org/readme
And best of all, it doesn't have to be highly detailed!
I'm actually in the pre-production stages of a very demanding independent "FX heavy" project. The major scene stealer in the film will require a completely 3D Manhattan, NY model. We plan on modeling lower Manhattan ourselves; however, I need an accurate model right now for animatics (which is why it doesn't need to be highly detailed -- just accurate). I want to start on these animatics as soon as possible, which is why I don't want to waist time modeling a low-res version myself.
Btw, I primarily use Max 8, but also have Poser 6 which will work for animatic purposes as well. I tried searching the forums, but didn't find much.
Thanks!
