Sun, Feb 2, 9:10 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 2:22 am)
Subject: Material PoserPhyton scripts won't work?
the-negative ( ) posted Sun, 18 February 2007 at 7:08 PM · edited Mon, 27 January 2025 at 7:39 PM
"NameError: name 'poser' is not defined"
I get this whenever I load up any of Faceoff's Realism wacros in P7. (It used to work)
Occlusionmaster stops working too (Nothing in the scene?) and I have no idea where to correct it.
I accidentally (permanently)  deleted my Poserscripts folder beforehand, and I REALLY do not want to do another install, so if the issues are related someone would be kind enough to help me through (hint hint, I do hope it's not frowned upon in here)
In This Twilight- My FIRST public poser work in 2 years!
Also the reason why I endorse postwork (:D)
Victoria_Lee ( ) posted Sun, 18 February 2007 at 7:46 PM
Hopefully you didn't empty your recycle bin and the folder is still there.
If you have your P6 python scripts folder, just do a copy into the Python directory in P7.  That's all I did to get all of my P6 scripts working in P7.  I use OcclusionMaster and the Realism Kits a lot so they have to work for me.
Hugz from Phoenix, USA
Victoria
the-negative ( ) posted Mon, 19 February 2007 at 8:13 AM
Well, I use the shift key when deleting- so that's a no-no for me.
If anyone can help by PM for a folder that has the basic scripts/resources (encrypted and all, for private use) for restoration, I'd really appreciate that. :D
nruddock ( ) posted Mon, 19 February 2007 at 2:32 PM
Check each script and add the following if required :-
import poser
This line can be added anywhere before the first line of code (easiest is just to add it as the first line in the file).
