Sun, Feb 9, 7:05 PM CST
Subject: Poser to Bryce eyelashes and eyebrows
Runt888 ( ) posted Wed, 09 May 2001 at 1:32 AM · edited Sun, 09 February 2025 at 6:54 PM
Attached Link: http://cs.colostate.edu/~graus
No matter what I try, I still can't seem to get eyelashes and eyebrows to look right when I import a Poser figure into Bryce. I've seen the tutorials on Brycetech and various other sites, but nothing I try seems to work. I've managed to get everything to look good except for the eyelashes and brows. Any suggestions? Thanks.
Taura Noxx ( ) posted Wed, 09 May 2001 at 3:02 AM
what I do is grab the eyelashes then in the materials I select an empty slot for the transparency in the top part of the dials, and also in the bottom part,this opens up a new texture b or c or whatever. Then in that open the parametric texture up. I load the same texture into a new empty box and load the transparency image in the alpha channel, hit the green tick and make sure the texture is set to blend transparencis (the arrow on the beside the texture boxes up the top) . It works for me.
Runt888 ( ) posted Wed, 09 May 2001 at 11:45 AM
That's what I try to do. I guess I don't have a correct transparency map. I'll try it again though.
thgeisel ( ) posted Wed, 09 May 2001 at 2:43 PM
im doing it a bit different if there is a seperate transmap:I select the eyelashes, set the diffuse color and the ambiente color to black, than i aktivate further down only one dot in transparency.in the windows that opens right on top i only load the transmap in the middle window. sometimes i have to invert the transmaps. let the blendmode to normal not to "blend transparency.works only ,when there is a seperate transmap
