Mon, Jan 27, 10:31 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 27 5:49 pm)
Subject: Free Truck and Cargo Trailer
Schurby ( ) posted Fri, 16 February 2007 at 8:56 AM · edited Mon, 27 January 2025 at 10:21 PM
 I just uploaded to 3D Commune a model of my GMC Diesel truck and trailer that I do some part time hauling with.
 Enjoy
 Giving Back
 Schurby
Schurby
David.J.Harmon ( ) posted Fri, 16 February 2007 at 9:14 AM
I forgot the url for that site? can you give it to me...
thanks
David J Harmon
davidjharmon.com
jonthecelt ( ) posted Fri, 16 February 2007 at 9:14 AM
Nice work, schruby... another one for my vehicles runtime... :)
jonthecelt
cherokee69 ( ) posted Fri, 16 February 2007 at 11:16 AM · edited Fri, 16 February 2007 at 11:19 AM
Schurby, awesome model. Thanks much.
Just sent you and IM.
EnglishBob ( ) posted Fri, 16 February 2007 at 11:16 AM
Excellent work, as always; thank you. May I make a suggestion? If bandwidth is tight, you could make the Zips smaller by omitting the geometry RSRs. Only Poser 4 requires them, and it makes them on demand. Just a thought. CappuccinoDavid: www.3dcommune.com
David.J.Harmon ( ) posted Fri, 16 February 2007 at 11:20 AM
EnglishBob: Thank you very much**
David J Harmon
davidjharmon.com
Schurby ( ) posted Fri, 16 February 2007 at 2:38 PM
 Good suggestion EnglishBob, I wasn't sure about that as I have Poser5 and seldom use it as I have learned 4 and am more at home with it. I had left them out at first and then added them back to the zip file. In the future I'll leave them out. I don't keep up with Poser much these days and I know they have 7 now since I started using Cinema 4D.
Schurby
cherokee69 ( ) posted Wed, 28 February 2007 at 8:49 PM
Don't know if you got my IM when this can out but there seems to be a little problem with the truck. When you open the doors, the mirrors stay in their default position and don't move with the door.
JHoagland ( ) posted Thu, 01 March 2007 at 7:06 PM
To clarify what EnglishBob said: you don't need to include the rsr files under the RuntimeGeometries folder. These files are only used by Poser 4 and if they're not found, Poser will simply re-create them.
Poser 5 (and above) doesn't use these rsr files anymore.
Basically, these rsr files just take up space in the zip file. ;)
But, don't confuse these with the rsr thumbnail files found in the RuntimeLibraries folders, which are needed to see what the item looks like.
VanishingPoint... Advanced 3D Modeling Solutions
pjbear ( ) posted Sun, 04 March 2007 at 8:55 PM
Really neat.
One frustration -- The Turbo writing on the passenger side is mirror image backward. I can't figure out how to get at it!!!! There does not seem to be an image map or? I am quite curious what is going on.
Help?
R_Hatch ( ) posted Mon, 05 March 2007 at 3:25 AM
It's geometry. The GMC logos on the passenger side wheels are also backwards. Fortunately, they are in a material group called gmcred, which can be turned into a group with the grouping tool, and then reversed with magnets. Notice that you'll want to use "reverse group normals" after using the magnet to flip them, and the magnet won't be entirely trivial to place.
Marque ( ) posted Tue, 06 March 2007 at 7:41 AM
Nice job! Any chance of a horse trailer and stock trailer?
Thank you for all the hard work you've done on these.
