Tue, Feb 25, 12:16 PM CST
Forum Moderators: RedPhantom
Subject: Interposer Ltd. only loads 8 frames in c4d?
danb ( ) posted Wed, 07 March 2007 at 4:21 PM · edited Tue, 25 February 2025 at 12:09 PM
I am only able to load 8 .obj files using interposer ltd. inside c4d.  I am using the demo.  Is the demo limited to only 8 frames?
kuroyume0161 ( ) posted Wed, 07 March 2007 at 4:51 PM
Yes! ;)
You can spread them out though using the dialog options (every nth frame and occupy frame range).  But the further apart the PLA keys, the more likelyhood of interpolation distortion.
Alternatively, you can also import the animation in sections.  This will create a new set of imported objects, but you can then drag-n-drop the new animation key sections to be appended to the initial ones.  Delete the new-dummy import.  Repeat and rinse until you have all of the animation imported and appended.
 -- Bjarne Stroustrup
danb ( ) posted Wed, 07 March 2007 at 4:53 PM
Ok that's good to know.  If i purchase the interposer ltd. will i be able to import more frames?
kuroyume0161 ( ) posted Wed, 07 March 2007 at 5:17 PM
Of course.  As many as will fit into available memory. :)
danb ( ) posted Wed, 07 March 2007 at 5:18 PM
Ok thank you.  I will be purchasing soon. :)
