Bryce F.A.Q (Last Updated: 2024 Aug 28 6:28 pm)
OK, forget I asked.............I just did a google search for bryce rainbow, and found the old B3 one, which does still work in modern versions because it is an image based texture.
Problem solved.
The greatest part of wisdom is learning to develop the ineffable genius of extracting the "neither here nor there" out of any situation...."
Oh, where did you find it?
I looked but couldn't see anything but photos of rainbows in Bryce canyon.
Measure
your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Attached Link: http://www.structuretoobig.com/personal/tutorial_rainbow.aspx
Its here.................As I said its for bryce 3, but I downloaded the B3 scene file and then opened it in B5.The greatest part of wisdom is learning to develop the ineffable genius of extracting the "neither here nor there" out of any situation...."
Thanks, I've saved that for later use. Handy. :thumbupboth:
Measure
your mind's height
A long time ago, about bryce 3 I think, I had a mat which I could apply to a torus and get a rainbow which I could then place wherever I wanted it.
Of course I no longer have that mat, and after many tries cannot work out how to make a similar rainbow.
Does any one have any idea how I can go about doing this.
I tried uv mapping a torus, which does work, except that i can't alter the torus as you can bryce ones, so my rainbow is too thick.
