Fri, Jan 3, 7:33 PM CST
Subject: Delete lights froze my P7
yvonne. ( ) posted Thu, 15 March 2007 at 2:42 AM · edited Fri, 03 January 2025 at 7:25 PM
Is anyone else having that problem? I´m trying some tips from Practical Poser 7 but can´t delet the lights without P7 stops working, not by the script or "by hand"? It works just fine in P6.
I have installed SR1.
/Yvonne
My store at DAZ
My Renderosity store
pjz99 ( ) posted Thu, 15 March 2007 at 2:51 AM
I haven't had that problem myself, and I use the script method fairly often.  Does that happen with every scene?  With a blank scene with no content at all loaded?  What options do you have on e.g. binary morph targets, binary/compressed files?
My Freebies
yvonne. ( ) posted Thu, 15 March 2007 at 2:59 AM
It happens when I have a figure in the scene and without too. I haven´t tried a whole scene.
I´m not sure about the other settings, but both P6 and P7 are in it´s default settings because I just got a new computer jippie and just installed everything.
I don´t know if I hade this problem before I installed SR1.  It can´t be my computer because P6 works fine.
It´s no biggie, I can change the light that are already there, but it SHOULD work and it´s annoying ;-)
My store at DAZ
pjz99 ( ) posted Thu, 15 March 2007 at 3:04 AM
Try opening a fresh, blank scene with default lights and no content and see what happens.  Also take a look at those settings I asked about, although I wouldn't really expect that's your problem.
My Freebies
yvonne. ( ) posted Thu, 15 March 2007 at 3:13 AM
A fresh scene doesn´t work and I have "Use file compression" unchecked and "Use external binary morph target" checked.
hmmm...I tried to uncheck "Use external binary morph target" and then it worked?? I tried to check it again and it still worked, bot with the script and "by hand"??
Not sure what it was, but thanks.
/Yvonne
My store at DAZ
pjz99 ( ) posted Thu, 15 March 2007 at 3:43 AM
Very well!  :)
My Freebies
