Photography F.A.Q (Last Updated: 2024 Nov 13 3:04 pm)
Flatten image is basically the quick way of merging all the layers together using what you see on the screen as what comes out at the end. This avoids the problem sometimes of the image changing slightly depending on what order you merge the layers together.
Hope that helps (and as far as i know it is correct )
"In every colour, there's the light.
In every stone sleeps a crystal.
Remember the Shaman, when he used to say:
Man is the dream of the Dolphin"
Rich Meadows Photography
You can also merge visible layers, and mergine doesn't neccessarily flatten the image. The people at Adobe sure love to give us options!
Well, I never knew that!!! so technically speaking, which is the best method to use on photographs - for instance if I have a couple of layers with text on, one for the frame etc., which would be the best option to get the most accurate end result?
"I don't suffer from insanity,
I enjoy every minute of it."
:lol:
CCCD Photography CCC
Dezynz
Always keep your Photoshop file with all of it's layers intact. If you use Save for the Web, it will automatically flatten things for you. If you are saving it for high end printing, Flatten the whole thing.
OK - pretty much what I did anyway except I usually merge visible rather than flatten - but I'll use the flatten option from now on.
I usually save the layers as a PSD first anyway, just in case I want to go back and make any changes afterwards.
Thanks for the advice and thanks ejn for asking the question!! xx
:lol:
Dezynz
one other point to add is that extra layers will increase the file size so if you dont save for web as Kort says the file may be bigger that expected..
Danny O'Byrne http://www.digitalartzone.co.uk/
"All the technique in the world doesn't compensate for the inability to notice" Eliott Erwitt
Hi,
When working in Photoshop if I have a couple of layers I merge layers before saving the jpeg.
What does Flatten Image do please
Eddie
