Vue F.A.Q (Last Updated: 2024 Oct 17 8:34 am)
xStream is just Vue 6 Infinite + plugins for other 3D packages. It will render your vue scene as a background and composite your other 3D package's elements into the render. That being said, it doesn't work quite right at this time. And if you think Vue 6 Infinite has problems (memory, etc.) just wait until you try to use xStream...
At least version 6 is sorta usable (I use it with 3ds max/mental ray). Version 5 was totally unusable.
Yes, it will mix the elements, in a way...but the lighting never matches and right now, the 3ds max version has a huge bug where it won't properly cast shadows on objects in both scenes, so it isn't properly integrated 100% like you say.
The lighting is the most difficult thing to work with, because the native objects use the native lighting in your scene and aren't affected the same way by the vue lighting, even if it is supposed to carry over. The lighting is so bad that the final result "looks" like a bad composite.
You can see this even on e-on's demo renders for xStream.
Is it actually out yet? If so, anyone tried it? I am thinking of sidegrading. Just wanted to get some trusted opinions first, so came to you all.
