Wed, Nov 20, 12:26 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 20 6:12 am)
Subject: Creating a prop from a V3 figure's head - strange behaviour
jenay ( ) posted Thu, 22 March 2007 at 10:32 AM · edited Wed, 20 November 2024 at 10:24 AM
First I used a V3 character, posed her, added a custom face morph, etc. etc. then I used the Poser group editor to create 4 new static objects from the head, the eyes and the neck. after then I moved the original figure aside to see me new props. the head and eyes look OK for me. but there is a strange gap/fissure between the haed and the neck. I have no idea, why this strange fissure happens. I didn't move the new objects after creation. head and eyes seem to be OK - but the neck seems to be rotated - I have no idea why. see picture attached.
adp001 ( ) posted Thu, 22 March 2007 at 10:50 AM
In the original figure, the hole between neck and head is closed via  "blend zone" (joint).
JOELGLAINE ( ) posted Thu, 22 March 2007 at 8:45 PM
You can CHEAT to do it!  Nyahahahahahahahahahaah!
Select NECK>Objects>Create Magnet>SPAWN MORPH
Apply morph, and delete the magnet. Exporting the bent neck then SHOULD work because it's morphed then.
It's been a long time since I did this, but I think I'm remembering right. ^__^ V,,
I cannot save the world. Only my little piece of it. If we all act together, we can save the world.--Nelson Mandela
An  inconsistent hobgoblin is the fool of little minds
Taking "Just do it" to a whole new level!
Tashar59 ( ) posted Fri, 23 March 2007 at 1:47 AM
Why not just export the groups you want and import them back in. Do it as a whole group or as single groups.
Tashar59 ( ) posted Fri, 23 March 2007 at 1:48 AM
Click on univers to uncheck everything and select the groups you want.
Tashar59 ( ) posted Fri, 23 March 2007 at 1:49 AM
Check thes boxes, P7. looks different in other versions but still same boxes to check.
Tashar59 ( ) posted Fri, 23 March 2007 at 1:50 AM
import back in with everything un-checked.
jenay ( ) posted Fri, 23 March 2007 at 6:35 AM
Hi thanks - I'll try the export method and see if it makes a difference.
I thought I could do the same with only the group editor.
also will test the magnet method - thanks :)
jenay ( ) posted Mon, 26 March 2007 at 8:07 AM
HI all -
the export-mothod worked :)
however the "spawn-morph-target-trick" via magnets didn't work.
Thanks again :)
JOELGLAINE ( ) posted Mon, 26 March 2007 at 8:15 AM
Like I said, I couldn't remember what I did to get mine to work.  It doesn't matter if one of the methods worked for you!
