Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 24 4:22 pm)
When importing into Poser, make sure everything is unchecked on the import options dialog. If the rifle is too big, set your export options in Wings3D so that you will get proper morph targets.
I forget what Wings3D's default import/export scale is but mine is set to 20.0 for import and 0.05 for export. It sounds like you may already have these set properly, but I just wanted to make sure :)
Attached Link: http://www.drgeep.com/p4/morwings/morwings.htm
You can look here at Dr.Geep:Morphs may not be the best way to move parts. Making parts move on prop, parent the moving parts to the gun and you can use the joint editor to adjust the parts center and endpoints. Rename the trans/rot dials to say something like open/close or forward/backward, up/down or even cocked/uncocked. Set thier limits and hide the dials you don't need.
There is also the Phibuild and Sams3D had a very good tutorial on how to use it. Don't know if they still do but they are pretty good at helping if asked.
Quote - Morphs may not be the best way to move parts. Making parts move on prop, parent the moving parts to the gun and you can use the joint editor to adjust the parts center and endpoints. Rename the trans/rot dials to say something like open/close or forward/backward, up/down or even cocked/uncocked. Set thier limits and hide the dials you don't need.
Is that Phibuilder by Roy Riggins or something different? If it is then here is a direct link to his site.
The setup room isn't really appropriate for a machine-type model.
The basic steps:
Before getting into Poser, make sure that everything which moves together
is part of one Group in the object file. For instance, if your bolt has a main
sliding part that's blue metal and a protruding handle that's wooden, and both
of these pieces are rigidly connected, the blue and the wood should be
distinct materials and both should have the same Group name.
Bring into Poser to get the scale and location right, as I mentioned before,
and export.
Import the exactly scaled OBJ into Poser with all boxes unchecked.
In the material room, apply materials to the Usemtl zones.
Click on the grouping tool. Hit the 'Spawn Props' button. Close the grouping tool.
Hit the delete button to get rid of the original OBJ.
At this point you have the Groups still in their proper places, but each is
now a separate prop in Poser. Use the Hierarchy window to set up the parent-child
relationships, with the "most central" thing (maybe the stock?) as the top parent.
Select the top parent and hit the Create New Figure button at bottom of
the hierarchy window. Poser will set up a CR2 in the New Figures folder.
9. Get rid of the props and load the new CR2. Adjust the offsets (joint centers)
of moving parts, and resave in a better folder.
10. Edit the CR2 to make the Tran parameters visible on any pieces that
need to slide, like the lever or bolt. (Figures by default have only the rotate
and scale parameters visible.) Also change all 'bend 1' to 'bend 0' in the
whole CR2, so the stock won't go all warpy and weird when you pull the trigger!
My python page
My ShareCG freebies
I had put a post up earlier similar but not exact to this.
I have made a model of a rifle and would like to know if there are any tutorials out there explaining step by step exactly how would i get the lever & hammer to move. I am using wings 3d for the modelling, poser for the rendering and posing i would just like to know exactly where i am going wrong.
At the moment i have it so a majority of parts can be textured but when i load it into poser and add the morph targets the rifle seems to move along the y axis.
Any help with a tutorial would be greatly appreciated
P.S i would also like to thank the two people who helped out on my last post
