Mon, Jan 27, 3:36 PM CST
Subject: Getting DOTS when Making GI Atmosphere presets lighter/more sunnny..why?
tebop ( ) posted Mon, 26 March 2007 at 2:57 AM ยท edited Sat, 24 August 2024 at 11:24 AM
hey guys i like to use GI ATmospheres cause they look realistic.. vue 5 infi by theway. But one that i like looks like a bit dark. so i increased the setting LIGHT BALANCE which originally was at 0. and moved it up to something more than zero. It's great and it looks as if it was a sunny day. But When i do this my renders get dots on the poser character. why is this and how to fix
tebop ( ) posted Mon, 26 March 2007 at 2:58 AM
This one is one of the normal GI atmosphere. no settings changed. looks great
tebop ( ) posted Mon, 26 March 2007 at 2:59 AM
This is the result of moving the Slider i told you about in the atmosphere settings. makes it nice and bright but i get dots
silverblade33 ( ) posted Mon, 26 March 2007 at 8:19 AM
wonder if that's linked to bug I got that created square black dots?
tebop ( ) posted Tue, 27 March 2007 at 8:27 AM
So what would the solution be? Not use this setting? MM,, thats too bad
haegerst ( ) posted Tue, 27 March 2007 at 8:58 AM
You should report that bug to e-on tech support so they can fix it.
Vue content creator
www.renderarmy.com
wabe ( ) posted Tue, 27 March 2007 at 9:12 AM
Could it be that you have a light source in the scene with a value of softness higher than let's say 9? This can cause this sort of problem.
tebop ( ) posted Tue, 27 March 2007 at 9:38 AM
No i don't have a light source other than the sun. All i do is load the atmosphere called Skydome, which is a GI atmosphere. then i go to settings and increase the slider called "LIght balance"' and "lightt intensity" Well anyways thanks. I did a couple of other renders and this time i didn't get dots. so who knows.
tebop ( ) posted Tue, 27 March 2007 at 9:46 AM
no don't have light surces other than the sun. I did a couple of other renders, and i didn't get the dots anymore. So, it must be a bug. look, this one has no dots
