Yes but only when you go to the EXTRA TROUBLE of creating and embedding a "Vue style" alpha layer. Meaning a separate black and white alpha.
Most programs automatically embed a transparent layer when saved as a PNG or TIFF.
So surely Vue has some setting I'm missing that lets it take advantage of this transparent layer.
It makes no since for them to not use an industry standard.
No, Vue recognizes the embedded alpha in the tiff image, and offers to load it in the transparency channel. No need for a "Vue style" alpha, which doesn't exsit, btw.
Maybe you should check the alpha channel of your image in a paint program, to see if it is right.
I'm sure I'm right about tiff, but I never used png, so what you could do is save your png as tiff in a paint program, and see if it works then. If it does, then there is a bug with the png format.
Well I be damn! You're right. Now all of a sudden TIFF, TARGA and PNG work great.
I can't even re-create the problem I was having. So great!
I'm thrilled I'm wrong. Sorry I doubted you Vue.
Now if I could just get the multipass SHADOW image to export with a transparent background.
I keep getting the shadow background as solid white, then I have to select and delete the white from every frame. AND I made sure I selected Vue's "embed alpha info."
You can advantage of the automatic connexion of the alpha output to the grayscale of an image used as a texture to make decals out of images that have no embedded alpha (.jpg, bmp..)
For the shadows, if you need a .png of your shadows on a transparent background, you can use the Shadow mask created in the Multipass and use PS or similar to add it as an alpha channel in the rendered picture.(you'll have to negative it first).
Then, save the new image as a .png.
Paul
Ah ha ... here's the problem Bruno021.
Loading one image, Vue loads the alpha. But if you load a sequence of images, it DOES NOT.
So Polax, you've got the answer, but I couldn't quite follow your guide. I added the filter to the alpha side, but all I got was a semi-transparent image. It didn't seem to key out the white.
Is there a tutorial on this? And thanks.
of course in this case, you have to make background color pure white and if this pure white appears elsewhere in the image, it will become transparent too...
You might as well choose another shade as background, depending on the subject (bright values), black could be more convenient.
The idea remains the same: via the filter, eliminate all values BUT the one used by the background.
(hope it makes sense.. :) )
... when I don't see one thing that controls the "Alpha" settings.
I've imported a PNG image which I know has a transparent alpha channel, so how do I key out the unwanted portion without haveing to go generated a separate "black and white" alpha image?
