Fri, Nov 15, 11:37 AM CST
Renderosity Forums / Blender
Welcome to the Blender Forum
Blender F.A.Q (Last Updated: 2024 Nov 10 9:28 pm)
Welcome to the Blender Forum!
   Your place to learn about Blender, ask questions,
   exchange ideas, and interact with the other Blender users!
   Gallery | Freestuff | Tutorials
Visit the Renderosity MarketPlace. Your source for digital art content!
Subject: Stuck in object mode
menschtx ( ) posted Fri, 06 April 2007 at 5:11 PM · edited Fri, 15 November 2024 at 11:28 AM
After trying the Truck the Camera in wikipedia - from noob to pro. I find myself stuck in object mode. I need suggestions about how to returen to Edit Mode.
oldskoolPunk ( ) posted Fri, 06 April 2007 at 6:39 PM
Make sure you have selected your model (RMB) before hitting TAB to enter edit mode. When selected, the object will be outlined in pink.
menschtx ( ) posted Sat, 07 April 2007 at 5:55 AM
Yes, its outlined in pink, but even when either hitting the tab button or clicking on the edit button, it stays the same. But Ah, I will rmb the model first -
If when I want to put textures on the model must I use the uv mapping for each of the items on the model?
Tobak30 ( ) posted Sun, 08 April 2007 at 6:02 PM
No need for uv mapping to add textures. There is a material tab down under the edit button shaped as a ball. choose one object or several and click that. Now you can push add new to get material aplied on it. You can make it in any colour you wanna. Then there are several options there where you can make it reflective or see thrue. You can also apply prosedural texture such as stone or wood by choosing the thingy that looks like a cheese ful of holes. Just play around and see what you get. :)
menschtx ( ) posted Wed, 11 April 2007 at 5:16 PM
Tobak 30, I've tried what you suggested. I am wondering is there ' group' to undo, thus seperating the objects for texturing?
Tobak30 ( ) posted Fri, 13 April 2007 at 2:41 AM
Attached Link: uv mapping tutorial
Do you mean uv mapping? Then I have provided a link to a tutorial that explain this method in an easy way.
menschtx ( ) posted Sat, 14 April 2007 at 5:52 AM
Sorry - not uv mapping. I sorta got that figured out.
When applying textures to a model which say has 10 different items or objects in it, my problem is seperating each object to apply a texture to. All the objects seem to accquire the same texture or color.
This is the main issue at hand, I have checked out just about all the tutorials, the wikipedia blender, blender.org and more. None give a definitive answer to either un grouping like bryce or give an answer about applying textures to single items in a large group.
oldskoolPunk ( ) posted Sat, 14 April 2007 at 11:38 AM
Hi menschtx.
You can either split the items into separate objects, or use material groups. Remember there is a 16 mat limit on each object. This thread shows both ways.
haloedrain ( ) posted Sat, 14 April 2007 at 8:17 PM
Are they all separate objects?  (can you select them in object mode separately?)  If so, select one of them, go to the material tab and click the little arrows next to the material name and select ADD NEW.
