Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 11:41 am)
You may already know this, but it's best to work in the 'flat' cameras
like Front, Left, Right, Top, Bottom when doing joint centers. In the
usual Main and Aux cams, things get slippery as you describe.
My python page
My ShareCG freebies
xantor
after you fix the joint parameter center where you want it next step is try to fix the other joint parameters centers next and before to this until the deformation be compensate,example a hand the next would be the fingers and ForeArm centers also the others parameters have part on fix it include the spherical fall of to.hope this help in some way
I am making a figure and need to centre a joint. The problem is that when I change the position of the joint the whole figure part moves. Is there any way to reposition the joint centre without the figure part moving out of position?
