Tue, Jan 28, 6:22 PM CST
Subject: another ecosystem question-inside an object
thlayli2003 ( ) posted Wed, 11 April 2007 at 1:20 AM · edited Mon, 27 January 2025 at 9:07 AM
Does anyone know if it is possible to get an ecosystem inside a booleaned cylinder?  Kind of like those pics of old space station ideas with the cities on the inside.  I want the ecosystem to go all the way around the inside of the cylinder.  have tried the things within my limited ability and have reached a dead end.  The picture shows what I mean.  Could also be used to make a deep pit like in the StarWars Sith movie.
thlayli2003 ( ) posted Wed, 11 April 2007 at 10:54 PM
Anybody...???? :)
Trepz ( ) posted Thu, 12 April 2007 at 1:56 AM
Not to sure how to help out,but I am most curious about this Sith movie..do tell:D
"Many are willing to suffer for their art. Few are willing to learn to draw."
chippwalters ( ) posted Thu, 12 April 2007 at 5:17 AM
My guess is you'd have to do it in sections. I've actually spent time setting up a scene like you describe, but didn't get too far with the final image. Break up your scene into a smaller boolean, use a view like this stunning one, created by Alexander Preuss.
It's a tricky setup, but it can be done.
Best of luck, Chipp
Rutra ( ) posted Thu, 12 April 2007 at 9:55 AM
I never tried it myself but, from my experience, I can imagine two different workflows:
a) Using Ecosystem Paint feature (only available in V6). You do not click on "populate". You just paint your ecosystem in the visible top part of your object. Then you rotate the object and paint the ecosystem on the new top part. And so on, until everything is painted. That's really easy, I think. And you have precise control over what's painted.
b) If you dont have V6, you can click "populate". Then duplicate the object and rotate it, as many times as you need to cover everything. Finally, you make the base texture of the duplicated objects 100% transparent. This has the disadvantage of you getting equal patterns of the ecosystem, which, depending on your population, might become too noticeable. If this is the case, when you duplicate the object, you can click "clear" and "populate" again on the duplicated object. You might have to adjust the rotation in this case.
I haven't tried any of these methods but do drop me a PM if this works! I'd be interested to know! :-)
thlayli2003 ( ) posted Thu, 12 April 2007 at 11:43 AM
Thanks for the ideas.  I am using V5i so don't have the paint.  I figured I'd have to do it in sections and rotate.  Just hoping I'd missed something easy.
I'll have a sample up today.
