Thanks. I use V5Esprit. I've noticed that the problem is more pronounced when I drag the terrain beyond the perimeter of the ground.
When you restart Vue, I assume you save your scene beforehand and then open it up again when you've restarted ? .... otherwise you might end up going thru' the same hassle...
Not sure if I had the same problem in V5, but probably did (I generally ignore the perimeter of the ground when resizing, but recall that at one time... maybe in V4... that was a big problem). In answer to your question, tho, I save everything.... and always with a new name. Just delete the old files once you know you don't need them anymore.
So, does restarting solve your problem?
Hi all,
I have added two terrains to my scene. I add a third terrain and move it. I then attempt to resize it (using the global resizing handles), but nothing happens.
It doesn't appear to be running out of memory as I am still able to move it around, and there is no other strange behavior.
Any help, please ?
thanks,
Andrew
