Wed, Feb 19, 1:22 AM CST
Subject: How Do I Remove This?
LMcLean ( ) posted Mon, 23 April 2007 at 12:32 PM · edited Mon, 23 October 2023 at 7:20 AM
The problem is the light horizontal band across the sky and sphere. I want to have the background of my Spectral Atmosphere all one color so the reflection on the sphere doesn't have a horizontal line. I tried to remove the fog, haze etc. Then I tried to change the height of the sky etc. No luck after playing around for 2 hours. Do any of you know how I can fix this? Thanks
LMcLean ( ) posted Mon, 23 April 2007 at 12:33 PM
And here's my settings
bruno021 ( ) posted Mon, 23 April 2007 at 12:42 PM
Try changing the aerial perspective to one, and set haze density to zero.
lingrif ( ) posted Mon, 23 April 2007 at 12:44 PM
You can also try moving the sphere higher and aiming the camera up.
www.lingriffin.com
keenart ( ) posted Mon, 23 April 2007 at 1:04 PM
Yo could also try turning the ground plane into a mirror.
jankeen.com
wabe ( ) posted Mon, 23 April 2007 at 1:15 PM · edited Mon, 23 April 2007 at 1:19 PM
Attached Link: http://www.wabe3d.de/exchange/Colors.zip
I enclose some old atmospheres I did when I created a series with only monochrome colors as background. Maybe that helps.
Victoria_Lee ( ) posted Mon, 23 April 2007 at 1:39 PM
The easiest way is to rotate your camera so that the horizon is well below the sphere.  Setting the haze and/or fog to 0 will help, too.
Hugz from Phoenix, USA
Victoria
agiel ( ) posted Mon, 23 April 2007 at 2:09 PM
Or you can use a vertical plane with a flat color and place it behind your sphere, large enough to take the whole field of view.
LMcLean ( ) posted Mon, 23 April 2007 at 6:40 PM
Thanks All, I will try your suggestions and see what works best. Thanks for the files Wabe! I will look at them.
LMcLean ( ) posted Mon, 23 April 2007 at 6:45 PM
Wabe, Can't seem to open the files.
wabe ( ) posted Tue, 24 April 2007 at 12:32 AM
What do you mean? The zip is corrupted? The files can not be loaded as atmospheres?
LMcLean ( ) posted Tue, 24 April 2007 at 2:00 PM · edited Tue, 24 April 2007 at 2:00 PM
Walther, Sorry my mistake. I didn't realize they were atmospheres. The files work fine and look great. They should come in handy. Thanks
wabe ( ) posted Tue, 24 April 2007 at 2:40 PM
Good - now show us the result!
