Fri, Jan 24, 1:07 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 24 12:37 pm)
Subject: Can I change a Bryce 5 or 6 file named .OBP to work in poser 7
rowlando ( ) posted Mon, 23 April 2007 at 8:41 PM · edited Sun, 19 January 2025 at 11:32 PM
Help any way, I have Bryce 5 and 6 also wings3d, its a an OBP file for landscape
Thanks Rowlando
Seek what you can never loose
Mystic-Nights ( ) posted Mon, 23 April 2007 at 9:17 PM
Once the terrain is loaded press the "E" icon to the right. Once in the editing room press "Ctrl D" to export to 3ds, obj etc.
rowlando ( ) posted Tue, 24 April 2007 at 4:41 AM
Thanks Mystic- Nights I will try it, I have not used Bryce very much so I hope I can load it
Rowlando
rowlando ( ) posted Tue, 24 April 2007 at 7:20 AM · edited Tue, 24 April 2007 at 7:30 AM
Hi Again
I followed your instructions above, I can load it as a create object terrain but can not see the E you speak off above.
M then U  no E for edit room.
Can you tell what I can do.
Thanks Rowlando
Mystic-Nights ( ) posted Tue, 24 April 2007 at 5:08 PM
Here is what I get when I load a terrain in Bryce 6.
rowlando ( ) posted Tue, 24 April 2007 at 6:43 PM
Thanks Mystic-nights
Yep, I don't get that display on the OBP file I load.
I think you cannot export anything except terrain as a different file such as I want, not sure if its true.
Could you open an OBP file and try export as obj for me to see if its true.
Thanks Rowlando
pakled ( ) posted Tue, 24 April 2007 at 7:42 PM
in a word...no. Best thing to do with your stable of programs is to make .obj files in Wings 3d, and import them into Poser. 2 tips- bevel all edges about .02 or so, to keep them straight on import, and scale; Poser scale is much smaller than everyone else's. If you have Wings 3d questions, stop by the Wings forum and ask.
rowlando ( ) posted Tue, 24 April 2007 at 9:05 PM
OK Paklad
Will give it a try thanks
Rowlando
Mystic-Nights ( ) posted Tue, 24 April 2007 at 9:19 PM
Attached Link: http://forum.daz3d.com/viewtopic.php?t=13148
Yes, I went to "Create" and added a Terrain. Then once in the Edit room clicked Ctrl D and exported as an obj. It worked fine in Poser. Here is a post at Daz on exporting from Bryce.
rowlando ( ) posted Tue, 24 April 2007 at 10:55 PM
Hi Mystic-nights
Thanks so much,
Back to Bryce 5  well, maybe I am adding the OBP incorrectly ( I find it in the create pannel click and press return to load)
But when I see it in the scean the E is really missing from the list. I have looked at the link you supplied and giving it another go, any other suggestions please.
Rowlando
jelisa ( ) posted Wed, 25 April 2007 at 12:33 AM
You are loading the OBP correctly, i.e., from the Create Library.
Does the loaded object have a "U" next to it? If so, then it is a group and may contain a Bryce primitive, which cannot be exported unless you are using Bryce 6 - which is why there is no "E" next to the object.
In Bryce 6, if the loaded object is a group, click on the "U" button to ungroup it, then select each object in the group and set them to positive, select all the objects and group them again. Next, click on the "C" button that will show up next to the new group and then export the converted group using File > Export.
rowlando ( ) posted Wed, 25 April 2007 at 12:47 AM
Ok Jelisa
I will give it a go in Bryce 6
Thanks very much
Rowlando
rowlando ( ) posted Wed, 25 April 2007 at 7:48 AM
Hello Jelisa
I have been trying but getting some very poor results, I think I am doing somthing wrong in the process can I ask you to explane it again as you have above in detailed steps for someone who is not used to Bryce.
I the file menu I can select all or deselect all, this has been the only way I could do any of the above, is their a place where all the sections of the objects are shown as names etc??
Please if you could explane the process in detail I am sure I could do it, my conversions are upside down and distorted.
Thanks Rowlando
