Fri, Dec 27, 7:58 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 26 8:04 pm)
Subject: MOVING CHARACTERS ON A POSER SCENE
surgeon3d ( ) posted Sun, 06 May 2007 at 4:17 PM · edited Fri, 27 December 2024 at 7:49 AM
Hi, does anyone know how can i move a character from its original position to another position on the scene ??  I want to make a scene using two characters and when i load the second character on the scene, the second character is loaded in the same place as the first character.  HOW CAN I MOVE THE FIRST CHARACTER TO ANOTHER PLACE ???
Acadia ( ) posted Sun, 06 May 2007 at 4:35 PM
User the X and Z Trans dials to move the figure left/right or backwards/forwards
You can also use the Scale dial to resize the figure once you have it placed where you want it.
FrankT ( ) posted Sun, 06 May 2007 at 6:18 PM
make sure you select the figures body, not the hip - for some reason poser seems to default to the hip which won't move the whole figure
My Freebies
Buy stuff on RedBubble
Angelouscuitry ( ) posted Sun, 06 May 2007 at 7:31 PM
One thing to keep in mind, when moving from the Hip, is if Figure > IK is turned al the way on, or all the way off.
If you want to save the position you've moved youor  character to, then you use the Hip,  If you have the Hip selected, when you save a pose.pz2, then upon loading that .pz2 the new figure's Hip will be moved to where the Hip was when the .pz2 was saved.
surgeon3d ( ) posted Tue, 22 May 2007 at 6:13 AM
thanks everybody you solved my problem
