Tue, Nov 19, 9:38 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: Replace ImageMap script
nruddock ( ) posted Mon, 07 May 2007 at 12:37 PM · edited Tue, 19 November 2024 at 7:26 AM
file_376852.doc
As requested by LostinSpaceman in this thread -> [ http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2696482](http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2696482)
Examines all materials in current figure, produces a list of images used. One image is selected for replacement by another (selected via Poser's built-in texture dialog). A MaterialCollection containing all the current figures materials, can be saved after image replacement.
Requires Python access to Material Room so for P6 and P7 only.
Tested (lightly) in P6 and P7.
Usual routine, download attached file, rename with .PY extension (recommended name ReplaceOneMapAllMats.py)
Any discussion or problems, please use this thread.
LostinSpaceman ( ) posted Mon, 07 May 2007 at 1:08 PM
Thanks Much! This will save a lot of time.
Connatic ( ) posted Mon, 07 May 2007 at 5:33 PM
Thanks, nruddock!
