Thu, Jan 23, 6:22 PM CST
Forum Moderators: Staff
Subject: Is there a utility program for this?
MamaBird ( ) posted Mon, 07 May 2007 at 2:00 PM · edited Thu, 23 January 2025 at 3:16 PM
Does anyone know if there is a program that will extract objects from Poser's prop file and allow you to save them as external geometry?
nruddock ( ) posted Mon, 07 May 2007 at 2:13 PM
Quote - Does anyone know if there is a program that will extract objects from Poser's prop file and allow you to save them as external geometry?
A reasonable text editor is all that's needed (even WordPad is good enough in most cases).
Unless there is something special about the geometry for a prop, you can also just export from Poser (will be affected by dial settings and/or export options).
Miss Nancy ( ) posted Mon, 07 May 2007 at 2:14 PM · edited Mon, 07 May 2007 at 2:16 PM
I don't, other than saving as wavefront.obj in poser itself, or using a text editor in the rare cases where the geomCustom data is embedded in the pp2 file. oops - cross-posted with noel 😄
Indoda ( ) posted Tue, 08 May 2007 at 5:04 AM
Attached Link: Poser Tool Collection
There is a program that comes in Tool Collection for Poser by Ralf Sesseler in the market place - ExtractEmbedGeoms
The important thing is not to stop questioning.
- Albert Einstein
Indoda
jancory ( ) posted Tue, 08 May 2007 at 9:35 AM
or for free, try CR2Builder02k.
lost in the wilderness
Poser 13, Poser11,  Win7Pro 64, now with 24GB ram
ooh! i guess i can add my new render(only) machine!  Win11, I7, RTX 3060 12GB
 My Freebies
