Thu, Feb 6, 7:41 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 06 4:35 pm)
Subject: Whats closer in versions
jjroland ( ) posted Sat, 19 May 2007 at 12:24 PM · edited Thu, 06 February 2025 at 5:06 PM
I use Poser 6.  Often I will get props and stuff that come in P4, P5 and PP versions.  When presented with these options which should I choose?
I am:  aka Velocity3d
ghelmer ( ) posted Sat, 19 May 2007 at 12:28 PM
If it only has P4 & PP, I use PP.  If there's a P5 I use that.  I absolutely hate using a P4 version of something and have my P6 hanging for a few minutes then a popup searching for a *.bum or something!
Gerard
The GR00VY GH0ULIE!
You are pure, you are snow
We are the useless sluts that they mould
Rock n roll is our epiphany
Culture, alienation, boredom and despair
Carioca ( ) posted Sat, 19 May 2007 at 8:08 PM
Quote - If it only has P4 & PP, I use PP.  If there's a P5 I use that.  I absolutely hate using a P4 version of something and have my P6 hanging for a few minutes then a popup searching for a *.bum or something!
Gerard
I also hate that. If possible, I usually avoid P4 versions.
wdupre ( ) posted Sat, 19 May 2007 at 11:21 PM
always use P5 or up if its availible, if the choice is only P4 and PP then go PP but in that case you will need to go into the material room and move the bump map from gradiant bump to the standard bump channel.
jjroland ( ) posted Sun, 20 May 2007 at 11:07 AM
Thanks for your replies.  If it comes with P5 versions can I just delete the P4 and PP versions then>?
wdupre ( ) posted Sun, 20 May 2007 at 12:46 PM
yep
