Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2025 Jan 27 2:29 pm)
Sin for Victoria 4.
Sin. Secretly we all crave a little sin to some degree, so let your Victoria give in to her wicked side and give her an outfit for going out in that's made to be seen. Whether she's out nighclubbing, or just setting old mens hearts fluttering in the park, this is the must have outfit for her to be sinful in.
As always with Andi3d products, this set has been crafted from entirely new and unique geometry, and has templated textures for everything. The blank texture templates are also included, for making custom textures.
This set requires DAZ Victoria 4 to work properly, and Poser 6 or newer.
The Pack Contents.
The set is made up of four individual cr2 clothing figures, comprising of Boots, Skirt, Stockings and Top. The stockings are only intended to be used with this set (or alternative knee length boots) and so have only been set up to deform properly above the knee where they are visible. Movement on the skirt is controlled by dials, which gave a smoother result than conforming body parts. The top has adjustment morphs for collar movements, which are included on the body, in their own morph group, as there are rather a lot of morphs on the top for body shaping. Various adjustment dials are included to compensate for any pokethrough that may occur as a result of unforseen combinations of character movement. All the adjusment dials can be found on the body part concerned, or the body of the particular clothing figure.
All the clothing figures contain a variety of body shaping morphs, made up of Full Body Morphs and Partial Body Morphs.
Features.
-Unique original geometry ... detailed meshes
-4 cr2 conforming clothing figures
-Quality textures
-Selection of Full and Partial Body Morphs
-Additional adjustment morphs
Notes.
This product has been set up so that no pokethrough occurs within its normal operating parameters. Should pokethrough occur, there are a selection of morphs that will help compensate.Additional morphs have been provided for movements that may result in poke through, in areas such as knees and collars. If pokethrough occurs, use the Adjust dials to compensate.
This product has not been set up to conform to movements that are impossible for a human being to do, such as side-to-side movement of the forearms and shins.
This product has not been tested in Daz Studio.
This product requires Poser 6 or newer, as well as Daz's Victoria 4.
Character in renders is the wonderful JolinariV4 by .Artemis.
Hair is the awesome LongHairEvo (slightly modified) by Kozaburo.
All renders in Poser 6 Firefly, with no postwork.
"That which doesn't kill you is probably re-loading"
Now available at:
Andi3d
3d Commune
