Mon, Feb 3, 10:02 AM CST
Subject: Strange green artifacts on render with transmap hair HELP!
vincebagna ( ) posted Sat, 21 April 2007 at 5:01 AM · edited Mon, 03 February 2025 at 9:55 AM
Hi all!
Does someone know why i sometimes have these strange green artifacts, and how i could get rid off?
It's very annoying, it occurs with some of my koz hair (i didn't try all). This render uses HDRI map and GI, perhaps it's about that?
bruno021 ( ) posted Sat, 21 April 2007 at 5:18 AM
Can't see anything on the attached render, it's too small. Maybe, an area render blow up?
vincebagna ( ) posted Sun, 22 April 2007 at 3:07 AM
Well, you'll find it funny, but i was unable to reproduce that in bigger size. I mean even with a zoom in, the green areas were smaller again, but always there! It appear only with the antialias pass, and the shape changes with the pov.
I really don't know what happens! I don't know if it's a problem of transparency or something else.
Have you got any idea?
bruno021 ( ) posted Sun, 22 April 2007 at 3:58 AM
Maybe check the transparency tab in the advanced mat editor, an see if there is any "fading out" happening.
vincebagna ( ) posted Fri, 27 April 2007 at 5:35 AM · edited Fri, 27 April 2007 at 5:37 AM
No, there was no "fading out". But i found something else, it happened again with another scene, and no thransmap issue there. Sorry for the small attached render, but i could'nt get it bigger.
It's very very very annoying!!!
edit:
Perhaps it's about my antialias setting, cause it only appear with the antialias pass when tile rendering active?
vincebagna ( ) posted Wed, 23 May 2007 at 2:10 PM
A month later, the same problem again :(
It really appears to have to do with transmap. Here, the artifacts are localized around the "cap" of the hair (see the preview picture) where it touches the head. Except for the D3 picture, Each times it occured, it was there or near the eyelaches. So i really think it's a trans problem.
Anybody had the same problem?
nruddock ( ) posted Wed, 23 May 2007 at 4:41 PM
Quote - So i really think it's a trans problem.
One thing to try is to connect the transmap to the Specular_Value input and set the Transparency_Falloff to 0.0 (many older MAT poses leave the Falloff at it's default of 0.6).
If that doesn't cure it, you might try adjusting the Shadow Bias on any lights you have castinjg shadows (given that skull cap like parts are usually very close to the surface of the head).
vincebagna ( ) posted Thu, 24 May 2007 at 2:29 AM
Yep, but the problem occures into Vue6 Esprit, and not Poser. And for this one, i didn't use Poser Shader Tree. So i don't know what i could do. It's nothing i couldn't solve with postwork, but i would like to know what it happened...
nruddock ( ) posted Thu, 24 May 2007 at 3:49 AM
Quote - Yep, but the problem occures into Vue6 Esprit, and not Poser. And for this one, i didn't use Poser Shader Tree. So i don't know what i could do. It's nothing i couldn't solve with postwork, but i would like to know what it happened...
Sorry about giving info for the wrong app 😊
Some material settings must get carried over even if you don't use the Poser Shader Tree, so the problem is going to have a similar cause and solution (but in this case I don't know the specifics of the answer, but the transparency / highlight settings will be involved).
vincebagna ( ) posted Thu, 24 May 2007 at 4:30 AM
Here, no highlight issue because there is no light, only HDRI illumination.
dburdick ( ) posted Thu, 24 May 2007 at 6:43 AM
Try increasing the "Quality Boost" of your GI atmo to 1.0.  I sometimes get this problem with small images using GI
stormchaser ( ) posted Thu, 24 May 2007 at 8:13 AM
I could be wrong here, but I'm sure I've had this in the past but when I turned the AA settings higher the problem was gone. Just a thought.
vincebagna ( ) posted Tue, 29 May 2007 at 7:13 AM
@dburdick: Thanks a lot! I works with "Quality Boost" set up to 1. The artifact disappeared!
@stormchaser:
As you can see, my AA settings are already up (perhaps a little too much for my needs, but i saw a difference for the quality of the hair).
Thanks to all for your help. I've been long to answer, but i was on other projects at the same time.
