Tue, Feb 11, 5:48 PM CST
Subject: Poser 7 Subtle Lighting Advise Please
Torleon ( ) posted Fri, 01 June 2007 at 2:52 PM · edited Tue, 11 February 2025 at 2:03 PM
Would appreciate advise. I would like to position a light to simulate light from a candle flame, candle held in the hand, so need the realistic soft all round glow such a light would have, with that close body proximity. I can paint this well enough ( being a veteren ! ) but would like to attempt this in Poser. Many thanks in advance for any and all suggestions and advise.
Conniekat8 ( ) posted Fri, 01 June 2007 at 3:05 PM
Aside from positioning and coloring of your light, one of the things to tweak till it gives you wanted effect would be fallof.
If I'm visualizing this right, candle light doesn't cast a lot of light, so your falloff distance should be rather short, and pretty rapidly declining at first.
This is conceptually and off the top of my head, I don't know the exact names of setting and dials. I'll have to get that little later, when I have tiome to fire up poser.
raven ( ) posted Fri, 01 June 2007 at 3:09 PM · edited Fri, 01 June 2007 at 3:09 PM
Do you mean like this? If so, a point light set at the wick for the illumination. Then a ball prop placed over the light/flame with the material in the following post applied to the ball to give a glow effect.  Adjust the colour to taste :)
raven ( ) posted Fri, 01 June 2007 at 3:10 PM · edited Fri, 01 June 2007 at 3:11 PM
Set the ball to not cast shadows, and apply this material.
Click the pics to see them bigger.
SYNTRIFID ( ) posted Fri, 01 June 2007 at 3:34 PM
The falloff setting Conniekat mentioned is controlled by the "Dist End" dial in the light properties panel. It essentially controlls how far the light will travel, if set to zero it will go on forever.
Hey! His nose is dry! ... Someone should lick it,  just in case. - Diego
Torleon ( ) posted Fri, 01 June 2007 at 4:27 PM
Thanks for all that advise ! Really appreciate it, and will have another coffee and give it a whirl !
