Mon, Feb 10, 3:56 PM CST
Subject: Need Help Getting a Good Portrait Camera Setting
CStrauss ( ) posted Fri, 01 June 2007 at 2:43 PM · edited Mon, 10 February 2025 at 3:49 PM
I look around the gallery and see these awsome camera positionings to get a good close up portrait type shot of the head or pretty much 3 quarters of their body. My question is what camera settings do people use to achieve these im not very adapt at using camera dials, I can move the perspective to make it a bit bigger and drag z tran to move it in and y to move it up and down and what not, Perhaps to achieve these camera shots do  I need to play with other dials.
My shots tend to render pretty good but they just dont pop out at ya like some of the examples I included below. Which is the effect I'm trying to achieve. So if anyone can post some camera settings for me play with and learn from please do.
**Examples of What Im trying to achieve (not my work)
http://www.renderosity.com/mod/gallery/index.php?image_id=1437887
http://www.renderosity.com/mod/gallery/index.php?image_id=1432891
http://www.renderosity.com/mod/gallery/index.php?image_id=1429554
http://www.renderosity.com/mod/gallery/index.php?image_id=1446242
http://www.renderosity.com/mod/gallery/index.php?image_id=1448619 (nuity)
stormchaser ( ) posted Fri, 01 June 2007 at 3:40 PM
CStrauss - I think the first thing I'd change is your focal length. 35mm just doesn't give the right perspective, I use 150mm for my portraits. Other people will use different settings but I use this as a base.
Acadia ( ) posted Fri, 01 June 2007 at 5:42 PM
I have all of my cameras set to 105mm. I noticed that the head of my figures were elongated and asked about it and was told to use a setting of at least 105mm.  I've never tried anything higher as this seems to work fine for my needs.
stephaniebt ( ) posted Fri, 01 June 2007 at 6:26 PM
A__ has some lovely portrait packs which include poses and cameras. I use them a lot and they are very easy to tweak.
slinger ( ) posted Fri, 01 June 2007 at 6:47 PM
As everyone else has said, try adjusting the Focal length of your Poser Camera.
I've written a very quick tutorial on it here...
The liver is evil - It must be punished.
CStrauss ( ) posted Fri, 01 June 2007 at 11:56 PM
Thanks all for the tips and advice I just got home from work and going to cool down a bit from working and then jump in to poser and play with my cameras and thanks for the link slinger just quickly browsed through them but i will read more of them later tonight too they look interesting and I love poser tuts I always find something new to try.
I will post back with any questions i come across and progress thanks again
cspear ( ) posted Sat, 02 June 2007 at 10:11 AM
In the real world, you'd use nothing much shorter than an 80mm lens for portraiture (on a 35mm camera), unless you were after a distorted effect.
It's been a while since I did any photography, but I remember using a 100 - 200 mm zoom for head and shoulder shots.
I'd experiment with those kind of settings.
PoserPro 11 - Units: Metres
Adobe CC 2017
AntoniaTiger ( ) posted Sat, 02 June 2007 at 11:33 AM
The other half of the problem is the lighting. Have a look here for some standard lighting arrangements. And check the brightness and contrast settings on your monitor. It may seem odd, but "Brightness" sets the black level, while "Contrast" sets the white.
