Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 09 2:22 am)
If you go to your Poser folder (in C:Program Files assuming you have the standard Windows installation) and then in to Runtimelibraries you'll see the same folder structure that you do in the library. It will probably be easier to delete stuff that way; one big advantage is that it will go into the recycle bin, whereas deleting from within Poser does a permanent delete making it difficult to recover from any mistakes. :scared:
Quote - Thank for your reply.
When I click poser 1-5 figure folder it only gives me plus sign (to add) does not give me a minus sign.
You need to select the item in the library you want to delete before the - (minus) sign will show up.. So it's a one by one kind of thing here..
Hey! His nose is dry! ... Someone should lick it, just in case. - Diego
How do I remove figures from the library on the right side of the screen?
Like the figures I don't really use at all..(poser 1-5,,etc...)
I just have too many things on the side...it's really time consuming when I try to find things in the libray. (scrolling up and down..)
And if I do, will the program still run normally?
Thanks.
