Fri, Jan 10, 10:50 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 10:00 pm)
Subject: zbrush and poser help me ;(
max1276 ( ) posted Fri, 01 June 2007 at 12:39 PM · edited Fri, 02 August 2024 at 11:22 AM
Attached Link: http:///img.photobucket.com/albums/v333/max1276/poser1.jpg
Hi guys i am a poser user and i would to use zbrush3 to create a custom and personally morph for Victoria4 carachter or other carachter by renderosity,i export V4 from poser to Zbrush3 in obj format,and i modified and svae this from zbrush i open poser7 and delete the defaul figure SimonG2 file-import and select the caracther morph do in zbrush3 now i select only this option:Make polygon normal consistent and ok and open the file morph that i have created in zbrush but now appear this window and nothing
please help me, give me a correct procedure to export from poser to zbrush and from zbrush to poser to use the morphing
SYNTRIFID ( ) posted Fri, 01 June 2007 at 4:03 PM · edited Fri, 01 June 2007 at 4:08 PM
Well, I think it goes something like this...
Export the figure and make sure you keep all the internal names.  Edit the figure in ZBrush. If the morphs are going to be Full Body Morphs, (ie - if the morphing affects more than one body part, you need to be able to export each body part as a seperate obj.  If it is only one body part you want to morph, like the head for example, just export the head of the figure from Poser, bring that into Zbrush and work on it alone.
Then in Poser put Simon in the workspace and select each body part of the figure and  (Don't use the File/Import/ obj menu) Use the  the "Object" menu, select "Load Morph Target"  find the correct obj you created that relates to that body part, do this with all the body parts affected, then set them all to 1 and go to the figure menu and select "Create Full Body Morph".
Don't delete the original figure, re-save it as a new figure after you have loaded all the morphs and created the full body morph.
Hey! His nose is dry! ... Someone should lick it,  just in case. - Diego
SAMS3D ( ) posted Fri, 01 June 2007 at 4:25 PM
ooooo, I can't wait to try this too.  Sharen
pjz99 ( ) posted Fri, 01 June 2007 at 7:16 PM
did you look in the zbrush forum?
My Freebies
Parthius ( ) posted Fri, 01 June 2007 at 8:47 PM
Poser hosed up the vertex order when you export, so you have to either work on individual body parts (which means dealing with seams) or skip poser and Zbrush the original obj file (so that poser doesn't corrupt it). richardson has posted some threads on the subject. Since ZBrush doesn't handle the part and material groups that poser needs, you need to use UVMapper or something similar to put all the missing stuff back in before importing to Poser.
Life would be much simpler if Poser would export an uncorrupted obj file, but it doesn't.
