Sun, Dec 1, 7:27 PM CST
Subject: Poser 6 doesn't show BG Pic in Preview mode renders.why? i could do it in P5
tebop ( ) posted Sun, 03 June 2007 at 9:08 PM · edited Fri, 29 November 2024 at 5:47 PM
That's the whole question. Is there a trick on how to do it or did the makers erase this featuer?
Victoria_Lee ( ) posted Sun, 03 June 2007 at 9:33 PM
Check in the Material Room and make sure it's attached to the Background Node and that AutoFit is ticked.  I think that's what I had to do in P6 but I don't remember right off hand.
Hugz from Phoenix, USA
Victoria
tebop ( ) posted Sun, 03 June 2007 at 10:51 PM
i checked. and didn't fix it. This is what happens. I know the BGpic is applied when i import a BG pic. The way i know is if i pass the mouse over the BG..i will get like a grid...you can't see the full picture..but the grid lines are visible for like 1 second and you can tell it's the BG pic. In p5, you wouldn't get this grid. i think the picture would just appear fully. yeah. and it wuld stay on the bground visible no matter what you did. but this doesnt happen in p6
onnetz ( ) posted Sun, 03 June 2007 at 11:05 PM
I had all kinds of troubles trying to use a bg pic and finally gave up.. just map a plane as the bg.. works way better with no hassles.
Handle every stressful situation like a dog.
If you can't eat it or play with it,
just pee on it and walk away. :-)
I wouldnt have to manage my anger
if people would manage their stupidity......
AntoniaTiger ( ) posted Mon, 04 June 2007 at 2:31 AM
And feed the background image into the Ambient input on your background prop. Then you don't get visible shadows.
tebop ( ) posted Sat, 09 June 2007 at 8:24 AM
Ok guys look. This is what i mean. It's in Preview mode. A BG Picture. and you can't even see it. it's just the edges..so you can see a tiny bit. like a grid. It happens with bg quicktime movies too. I usually do it in Textured Preview mode..but this was just an example of what i mean. In P5 you would see the full bg image and full quicktime bg movie , even in preview mode. That sucks that they changed this in p6.
here
tebop ( ) posted Sat, 09 June 2007 at 8:26 AM
by the way. using a square and applying an image to it works...OK,,,but it looks blurry and weird. that's why i thought the BG picture or BG movie was a better thing
riskebiz ( ) posted Sun, 17 June 2007 at 3:23 PM
Same thing happens with me. Does no one have an answer?
tebop ( ) posted Sun, 17 June 2007 at 3:52 PM
yes .. risk, in another post i found the answer Just change PREVIEW DRAWING from Open GL to SREED SOFTWARE. it fixes it!!!
riskebiz ( ) posted Sun, 17 June 2007 at 6:23 PM
YEP. THANKS!
