Mon, Jan 27, 1:42 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 27 9:18 am)
Subject: Anyone else had this problem?
andrewe_665 ( ) posted Sun, 03 June 2007 at 6:05 PM · edited Mon, 27 January 2025 at 1:12 PM
You save a pose, exit the program come back another day, load the pose and no window appears but parameter dials show correct settings and it will actually render but still no window with render or preview in.
Lord_syphex ( ) posted Sun, 03 June 2007 at 10:50 PM
Double click on the window title.
andrewe_665 ( ) posted Sun, 03 June 2007 at 11:00 PM · edited Sun, 03 June 2007 at 11:01 PM
and? that will bring it up?
cyberscape ( ) posted Sun, 03 June 2007 at 11:41 PM
Lemme see, as I understand it, you are trying to load a saved pz3 and when you do, the document display window is missing. Right? If so, go into the top drop down menu and try to manually set the document window size. If not, could you post a screenshot, as I'm not quite 100% sure of what you mean.
AMD FX-9590 4.7ghz 8-core, 32gb of RAM, Win7 64bit, nVidia GeForce GTX 760
PoserPro2012, Photoshop CS4 and Magix Music Maker
...and when the day is dawning...I have to say goodbye...a last look back into...your broken eyes.
EnglishBob ( ) posted Mon, 04 June 2007 at 5:05 AM
Set up the workspace as you want it, then save it by clicking on a UI dot. (If there is some other type of dot visible, select the UI dots with the drop down list next to them.) Then, whenever your interface gets messed up, you can click on the dot to recall your favoured set-up. I have two of these set up: one with a square workspace, and one with a rectangular landscape format.
