Mon, Feb 17, 7:33 PM CST
Forum Moderators: RedPhantom
Subject: Faking Radiosity in Poser? How do YOU do it?
Conniekat8 ( ) posted Mon, 04 June 2007 at 12:43 PM · edited Mon, 20 January 2025 at 6:54 AM
I have to admit I don't do a lot of final renders in Poser, so I'm not up to speed on a lot of Poser specific tricks. A question has come up about how to fake some decent radiosity (global illumination) in Poser.
I know some people do it by setting up several lights, other play with texture settings etc...
Any tricks you guys and gals would like to share?
If there's ant doubt on what I mean by radiosity: http://en.wikipedia.org/wiki/Radiosity
Miss Nancy ( ) posted Mon, 04 June 2007 at 1:20 PM
P7 has IBL/AO using probe lights and hdri. so it's not really faking it. it might be as slow as molasses, though. they were faking it in P4 and P5 with those fake-GI lite sets consisting of dozens of dim infinite lites, but that's no longer necessary IMVHO.
Conniekat8 ( ) posted Mon, 04 June 2007 at 2:20 PM
Yea the above is true, however, I was trying scrounge some help for particular scene from a critique group. Sorry, I probably should have clarified that little more up front.
If I understood right the idea was to try and set up some lights to fake radiosity in the focal point area of the image. Perhaps with filler lights or tweaking texture settings. I don't think P7 or IBL was being used, hence the 'faking it' question.
Miss Nancy ( ) posted Mon, 04 June 2007 at 2:29 PM
there are 1 or more lite sets in freestuff for that. ask 'em what version of poser they're using. but it's a bummer having to set the shadowcams for all those lites IMVHO.
Conniekat8 ( ) posted Mon, 04 June 2007 at 2:43 PM
Cool Thanks :)
Maybe the person I was talking to will jump in with more specific questions when they get on line...
ima70 ( ) posted Mon, 04 June 2007 at 8:17 PM
Maybe this?
http://www.castleposer.co.uk/articles/shader_gather.html
Acadia ( ) posted Mon, 04 June 2007 at 8:30 PM
Attached Link: http://www.runtimedna.com/mod/forum/messages.php?ShowMessage=260819
Try this thread at RDNA.  Bagginsbill found a way to get great lighting using only 1 IBL light
SYNTRIFID ( ) posted Tue, 05 June 2007 at 7:02 AM
Quote - Yea the above is true, however, I was trying scrounge some help for particular scene from a critique group. Sorry, I probably should have clarified that little more up front.
Well, just to make a bit of a distinction here, Radiosity in itself is not the same thing as Global Illumination although it is an element that is a part of what causes it.  Radiosity is essentially bounced or reflected light, where if you have two objects close to one another, the color of one object will be projected onto the surface of the second object along the areas where the two (or more) objects are in closest proximity to each other, due to this reflected light.
Like if you place a red pool ball on a sheet of white paper, the bounced light from the red ball will cause a redish glow or tint on the paper where the ball is sitting. A blue or green ball will then reflect their own respective colors against the paper.
While the new AO and IBL lighting feature in Poser do a pretty good job at creating a global illumnation it is still not  "Radiosity".
Hey! His nose is dry! ... Someone should lick it,  just in case. - Diego
Conniekat8 ( ) posted Tue, 05 June 2007 at 12:24 PM
Quote - While the new AO and IBL lighting feature in Poser do a pretty good job at creating a global illumnation it is still not  "Radiosity".
Which is precisely why we're talking about 'faking radiosity' here, no?
SYNTRIFID ( ) posted Tue, 05 June 2007 at 2:10 PM
Quote - > Quote - While the new AO and IBL lighting feature in Poser do a pretty good job at creating a global illumnation it is still not  "Radiosity".
That would be my asumption. yes..  In Poser, using HDRI is a pretty decent "fake" because it applies the colors of the HDR image to the global illumination but it still does not actually calculate or photon map the bounced light in the true colors of the actual objects in the scene, so in essense, it's still "faking it"..
Willber ( ) posted Tue, 05 June 2007 at 10:14 PM · edited Tue, 05 June 2007 at 10:17 PM
Doesn't the GATHER node do this?
Page 323 of P7 manual
moogal ( ) posted Wed, 06 June 2007 at 1:38 AM
No, radiosity and global illumination are two different things.  GI simulates the indirect light from atmosphereic scattering, or ambient light.  Radiosity lets the colours and lighting properties of one object in the environment affect another.  Faking one isn't exactly faking both.
DgerzeeBoy ( ) posted Thu, 07 June 2007 at 1:23 AM
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2217752&page=1
Connie: I think this thread may be the answer to what you're looking for. Scroll down to Little Dragon's post.
Conniekat8 ( ) posted Thu, 07 June 2007 at 11:27 AM
BINGO!
Bookmarked!
Thank you very much :)
DgerzeeBoy ( ) posted Thu, 07 June 2007 at 6:14 PM
You betcha. Glad to help.
