Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 13 11:02 am)
Pedrith,
If you have Aiko maps just locate the eyebrow area of the graphic and using that file as a template create your own texture. Then go into the Material room, select your Aiko's eyebrow and apply your own map. Most figures are broken into a number of material zones. Should be a piece of cake.
Best Wishes,
If the eyebrows were done right and aren't painted on the texture map itself, you should be able to just use the transmap for them and then just change the diffuse color in the materials room. You can also mix and match transmaps from one texture and use with another if you like the look better.
Crazy alien chick FTW! (yeah....right....)
Realm of Savage - Poser
goodies and so much more!
Hi. I'm using Akio 3 with Poser 7. I am wondering if it is possible to create just an eyebrow texture that can be applied to Akio without changing the skin colour or altering anything else? If this is possible how do I go about doing it? Sincerely, David
