Fri, Jan 24, 7:59 PM CST
Subject: Quick Question, Delta-Inject
Impressions ( ) posted Tue, 19 June 2007 at 12:26 PM · edited Fri, 24 January 2025 at 7:54 PM
I am rather new at this so here goes another stupid question from a newbe.
Delta-Inject should end up in file system how?
1.   Runtime/libraries/pose/DAZ/ V3 or S3 or M3.
2.   Runtime/DAZ/V3 or S3 or M3
3.   Runtime/libraries/DAZ/v3 or S3 or M3
Should they be installed only in the origional runtime or in the download runtime?
I can't get Vicky to smile or open her mouth????
Victoria_Lee ( ) posted Tue, 19 June 2007 at 12:42 PM
The DAZ installer will put the files in the correct locations in any Runtime.  Which version of Poser are you using?  P5 and above will allow you to use external runtimes but, with P5, the DAZ unimesh characters behave best if installed to the basic Poser runtime.
Hugz from Phoenix, USA
Victoria
Impressions ( ) posted Tue, 19 June 2007 at 2:39 PM
I have both 5 and 6.  I am using 6 but can't seem to get the files to work properly.  I have moved them around several times now.  I will go try a fresh install of V3 and see if it works from a whole new install of the files.
Victoria_Lee ( ) posted Tue, 19 June 2007 at 2:54 PM
Do the fresh install to the base Poser Runtime.  That will put everything in their correct folders.
Anytime you move files or folders you have to be sure all of the associated folders and files are in the proper places so that the .cr2 files can find everything.  A lot of people do an extract/install to their desktop but I've found, especially with the DAZ installers, they do the job better than by hand.
Victoria
