Fri, Nov 15, 11:17 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 15 9:11 am)
Subject: scaling
menschtx ( ) posted Mon, 18 June 2007 at 10:07 AM · edited Tue, 13 August 2024 at 2:33 PM
Following the tutorial in efrontier's tutorial site the author indicates scaling: Scale it as follows- xScale 75%, yScale 100%, zScale 50%, which makes it look like a large bath sheet.
and then goes on to position the item at x, y, z.
My question is there a place to put in exact positions?
geep ( ) posted Mon, 18 June 2007 at 10:23 AM · edited Mon, 18 June 2007 at 10:27 AM
Attached Link: FREE Scale Props
Hi menschtx,** ** The **... xTran ... yTran ... zTran** parameters usually work for me. 😄
cheers,
dr geep
BTW - Have you ever heard about DGS?
cheers,
dr geep ... :o]
edited 10/5/2019
SYNTRIFID ( ) posted Mon, 18 June 2007 at 2:36 PM
Quote - and then goes on to position the item at x, y, z.
Click on the numeric field beside each respective  parameter dial, You can type in whatever value you want.
Hey! His nose is dry! ... Someone should lick it,  just in case. - Diego
menschtx ( ) posted Tue, 19 June 2007 at 8:11 PM
Thank you Syntrifid I'll try this
