Mon, Feb 3, 12:28 PM CST
Subject: With or without sr2, I STILL can't change camera views in P7
cyberscape ( ) posted Sun, 24 June 2007 at 12:54 AM · edited Mon, 03 February 2025 at 12:28 PM
Usually I use just the main and face cameras for rendering, so I have several UI dots of each set up (did this before installing even sr1). After sr1 and now sr2, I can't change my camera views using the dropdown menu at the top of the preview window. I luckily can still change views using the dropdown on 'camera controls' though. Anybody else have this oh-so-wonderful-and-delishiously-white-trash problem?
AMD FX-9590 4.7ghz 8-core, 32gb of RAM, Win7 64bit, nVidia GeForce GTX 760
PoserPro2012, Photoshop CS4 and Magix Music Maker
...and when the day is dawning...I have to say goodbye...a last look back into...your broken eyes.
pjz99 ( ) posted Sun, 24 June 2007 at 3:07 AM
Can you create a camera and switch to it?  I think you'd do that via Object menu -> Create camera?  It may be that the file(s) that defines the default cameras has become corrupted.
My Freebies
cyberscape ( ) posted Sun, 24 June 2007 at 9:57 PM
I tried creating a camera and it switched to it but, the only way to switch away from it is through the camera controls pallette. A corrupted camera file might be the problem. Any idea where or how I can fix that? Thanks for your help!
pjz99 ( ) posted Sun, 24 June 2007 at 10:06 PM
I don't know which files it'd be off the top of my head, and Poser isn't in front of me.  A lot of stuff goes in RuntimeUI, and there's also a user prefs XML file somewhere else (filename is something like userprefs1024x768.xml, depends on screen resolution).  If you have any other PC you might install Poser on it and patch it, and take the XML files that look likely from the clean install.
Be aware if you install a second copy on the same machine, it will probably screw up the first copy (registry settings).
My Freebies
Tyger_purr ( ) posted Mon, 25 June 2007 at 7:50 AM · edited Mon, 25 June 2007 at 7:52 AM
The dropdown at the top of the preview window does not change your camera view. that just selects the camera for moving.
if you want to change views right click in the preview area and choose a camera under the camera view.
personaly i prefer using the keyboard short cuts.... especially since you can edit your  Poser7/runtime/ui/poser.xrc file and make the shortucts what you want.
My Homepage - Free stuff and Galleries
pjz99 ( ) posted Mon, 25 June 2007 at 8:03 AM
Oops, you are entirely correct, I mixed that up with the right-click menu (oops!!)
My Freebies
cyberscape ( ) posted Tue, 26 June 2007 at 2:45 AM
"The dropdown at the top of the preview window does not change your camera view. that just selects the camera for moving.
if you want to change views right click in the preview area and choose a camera under the camera view."
Whoa! Thanks for that info! And here I thought it was a bug. See, I've jumped from P5 to P7 and in P5 you can change cameras in the preview dropdown.
