Fri, Nov 22, 2:14 PM CST
Forum Moderators: Staff
Poser Technical F.A.Q (Last Updated: 2024 Nov 13 12:50 am)
Subject: A question about importing .3ds files to poser
adh3d ( ) posted Mon, 21 May 2001 at 5:34 PM · edited Fri, 22 November 2024 at 2:12 PM
When i import a 3ds file to Poser 4.03, poser smooth all faces of the model, and the look isnt good. Is it any way poser dont do this? Can you select the level of the smooth of imported model in poser. thanks.
adh3d website
ScottA ( ) posted Mon, 21 May 2001 at 6:38 PM
I don't think there is a way to stop Poser from smoothing. But if you save the model in .dxf format it will not get smoothed. I think there are lines in .3ds and .obj files that start with the letter S which tells Poser it's OK to smooth them. ScottA
JKeller ( ) posted Mon, 21 May 2001 at 7:23 PM
Attached Link: http://www.daz3d.com/pages/broker/brokerreq(pict).html
Poser pretty much ignores the s line in an obj file. Knowing this ahead of time, you can make your model with beveled edges or coplanar edges. See the link above for an illustration on DAZ's site.
It's difficult to do this with after the item is already modelled, and a simple solution is, converting to obj, and then take it into UVMapper and "split vertices." This will un-weld all the polygons which stops the smoothing process and gives nice sharp edges.
adh3d ( ) posted Tue, 22 May 2001 at 11:41 AM
The problem is that i want some smooth edges and some sharp edges in the same model.
adh3d website
JKeller ( ) posted Tue, 22 May 2001 at 12:10 PM
Then you need to bevel or coplanar the edges you want sharp.
adh3d ( ) posted Tue, 22 May 2001 at 2:38 PM
thanks. i'll try it.
adh3d website
