Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 05 5:33 pm)
You need to retime the animation. To speed it up, shorten the total amount of frames, and leave the frame rate alone.
Pulldown menus>Animation>retime Animation
Hi, my namez: "NO, Bad Kitteh, NO!" Whaz
yurs?
BadKittehCo
Store BadKittehCo Freebies
and product support
sweet - I did that once but I didn't know what it did at the time lol. Ill go back in there and try that again.
I tried importing it into Vue to render but I somehow lost half the frames when going from poser to vue and now it goes super duper fast instead of slow.
wanting to buy middle ground!
I am: aka Velocity3d
Nope that does nothing at all. I've tried it with "this element" as well as with "all elements". Now I closed out that animation and loaded an old version of the scene. Created walk path and walk animation. It wanted to use 111 frames. I let it. Then I go to retime it (because yet again it's slow as hell) - source 1 - 111. destination 1-60. Hit ok - close box. Nothing happens. Reopen animation timing box and it says 1- 111 in both boxes again.
I am beginning to think it would be faster to render each individual frame I want and them put them at the correct time in Roxio or WMM myself.
You don't notice a change in the position of the keyframes in the Animation Palette? The animation will still be the same length but the keyframes should be closer together in the timeline.
That is odd that it isn't working for you, It always does for me... It is indeed puzzling..
Hey! His nose is dry! ... Someone should lick it, just in case. - Diego
Any tips on how I can speed up animation? I change rate but it doesn't seem to change the timing any and the animation is going VERY slow - like half of a step per second.
Thanks in advance
