Mon, Feb 10, 6:33 PM CST
Forum Moderators: Staff
Subject: P7 "freeezes" when turning the parameter-dials of figures ...
tigerkidden3d ( ) posted Sun, 01 July 2007 at 10:00 AM · edited Mon, 10 February 2025 at 7:17 AM
Hi,
I'm using Poser7 under Windows XP.
When I edit figures,bodyparts or props  with the parameter-dials like "xrotate" "ytran" and so on ..... more then lets say 5-10 times, Poser7 doesn't react anymore... "freeze" !!!!!
The ONLY thing I can do, is to save the file. Then I close Poser7 then and reopen the just saved file again, the last dial-move looks very strange, but everything else is fine until the next "freeze" after 5-10 "turning the dials".
With the same file, on the same PC but with Poser6 it NEVER happens.
Does anyone know what causes this problem?
Thanks.
Miss Nancy ( ) posted Sun, 01 July 2007 at 1:28 PM
it may be a memory problem, in the way poser reads and writes to virtual memory. but the experts may have a better fix. not certain if sr2 will fix this on all machines.
