Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 9:35 am)
The hair doesn't look like it simulated at all. Did you actually hit calculate dynamics for that all hair groups? When I do dynamic hair I usually sim it from the Animatino menu -> Recalculate Dynamics -> All Hair.
Try playing around with the gravity and resistance values; just make sure you save a backup, as it is very easy to wreck the sim settings. Ef really needs to investigate their wind system; the fluid effect as it stands works well on clothing, but seems to be in general too 'thick' to get the kind of hair sim we all dream of. There may be reasons why, but.....
is there any particular reason why you need to be using the wind turbines for that sequence,
'cause the way i see it is, if you were to turn them off and rotate that figure 180 degrees then the cloth would drape the same as above, and the hair would naturally drape to the position you require, and if you need fluctuation in the hair caused by a speedy decent, then by raising the figure quickly it would fluctuate,
all those frames would then just have to be flipped in your editing program, so that instead of looking like an ascending figure, it looks like a descending figure.
Quote - if you were to turn them off and rotate that figure 180 degrees then the cloth would drape the same as above, and the hair would naturally drape to the position you require, and if you need fluctuation in the hair caused by a speedy decent, then by raising the figure quickly it would fluctuate, all those frames would then just have to be flipped in your editing program, so that instead of looking like an ascending figure, it looks like a descending figure.
That is a good suggestion, for that matter you could try raising the figure up high on the first frame and bring it close to the ground on the last, with the 4 basic elements that affect dynamics being (gravity, wind, collision and motion) the motion of the figure itself falling at a rapid rate should create the desired effect at least similarly as it would in real world setting.Should be worth a try.
Hey! His nose is dry! ... Someone should lick it, just in case. - Diego
