Thu, Feb 6, 5:02 AM CST
Photoshop F.A.Q (Last Updated: 2025 Jan 14 1:57 am)
Are you up to the challenge??
Subject: Scanlines
Javil ( ) posted Tue, 03 July 2007 at 5:56 PM · edited Thu, 06 February 2025 at 4:57 AM
Hi,
i'm making a flash site and use a own photo with scanlines in it (fill, pattern 2x1 in photoshop)
Sometimes the scanlines looks fine, but when the browser resizes the scanlines give
a ugly effect. Does anyone know what i mean? This also is in photoshop when i resize the border.
Can anyone tell what to do about this problem?
Javil
more VUE Infinite on -> javildesign.com
retrocity ( ) posted Wed, 04 July 2007 at 7:02 AM
hey Javil, would it be better to do the scan line efffect within Flash instead of it being part of the image. this way the effect is vector and not pixel (subject to resizing artifacts...)
give it a try and see if it helps
retrocity
Javil ( ) posted Wed, 04 July 2007 at 8:14 AM
I will try that.  thanks :)
Javil ( ) posted Wed, 04 July 2007 at 9:13 AM
i doesn't work that great.
I can't find it in flash, so i did it in fireworks.
It is a little bit better now, but resizing is not possible because then it will give a strange effect.
Also i don't know if fireworks really uses a vector..
Do you know anything else...
thanks..
Prikshatk ( ) posted Thu, 05 July 2007 at 5:20 AM
Fireworks should work! If you have created the lines with the rectangle tool then they will be vectors..., you can 'save as' an SWF with 'keep as paths' and 'editability' options ticked... then the SWF will import into Flash as vectors.
regards
pk
www.planit3d.com
thundering1 ( ) posted Sun, 15 July 2007 at 11:16 PM · edited Sun, 15 July 2007 at 11:18 PM
When it is resized, it is no longer in the same parameters, and PS/your graphics card has to "figure out" what might be closest. What you should do is finish the image WITHOUT scanlines, resize it to the finished size to be presented/animated/shown/printed/whatever, and THEN apply the scanlines.
When it is a matter of the BROWSER having to resize something with a dense pattern, it will not be an even resize, and you will get the moire pattern. This is then the problem with your graphics card - not a bug, or a bad piece of equipment, but simple math for visual representation that doesn't match dimensions.
To see what I'm talking about more blatantly, make a 512x512 image in PS and apply the scanlines. When you view this at 100% it is perfect.
Hit Ctrl+Minus Key to zoom out, and it will zoom out (which will land at 66%) and it will have the moire pattern, do it again (which will display your image at 50%) and it will be perfect again. Do it again (now 33%) - moire pattern. Do it again (now displaying 25%) and it will be perfect.
In increments of 25% it will display correctly - ANYTHING ELSE and you will get the moire pattern. Your browser doesn't care - it is merely resizing so you are able to see all of the image, regardless of percentage.
End solution, size the photo to be the correct size in the finished product and NOT be resized by the browser, and THEN apply the scanlines.
Hope that helps - good luck-
-Lew ;-)
Javil ( ) posted Mon, 16 July 2007 at 7:39 AM · edited Mon, 16 July 2007 at 7:39 AM
Thanks!! That is clearly to me now!
It helps!!
thanks a lot,
javil
