Fri, Jan 31, 10:22 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
Subject: Apollo maximus clothing
fyrecomix ( ) posted Sat, 07 July 2007 at 9:27 PM · edited Tue, 28 January 2025 at 9:49 AM
Hi all,
I am using Apollo Maxiumus 2007 and the epic clothing.  I am attempting to make a halfling type character, so I used the ScaleCH_Dwarf to scale the body down.  I then did this for each piece of the clothing.  I thought this would work well, with some adjustments, but the shirt and sleeves do not seem to be fitting.  Any suggestions?
Thanks,
Joe
kalon ( ) posted Sat, 07 July 2007 at 10:25 PM
Try resetting the clothing to normal size, then switch to apollo scales set (where you used the ScaleCH_Dwarf dial). Go to edit -> copy. Then switch to the clothing, select body then edit -> paste.
kalonart.com
jefsview ( ) posted Sat, 07 July 2007 at 11:01 PM
And remember, when using the scaling options: do not conform.
Save the pose you want in your library and apply the pose to both Apollo and the clothing (which are scaled). But do not conform.
It should work then.
-- Jeff
fyrecomix ( ) posted Tue, 10 July 2007 at 11:28 AM
Ah ha...do not conform!  I will try these tips out...thanks for the quick response.
Joe
