Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 23 1:20 pm)
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2416168
See linked thread.If setting "Normals_Forward" doesn't help, there may be some other material settings that need adjusting, so screenshots would be useful.
It does look like a case of inverted normals. Try the normals forward box in the material room first, if that doesn't work, you might try using the grouping tool, select all the polygons in the area that is rendering dark and click "Reverse Group Normals"
Hey! His nose is dry! ... Someone should lick it, just in case. - Diego
I have tried everyting to get that bottom row to render textures, but it absolutely refuses to. I have tried every option in the render options... even Poser 4 rendering, but nothing works. Anyone else have thsi problem and/or know how to fis it?
