Thu, Dec 26, 8:15 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: running two scripts together?
alpha117 ( ) posted Tue, 10 July 2007 at 3:00 PM · edited Wed, 25 December 2024 at 7:51 PM
I use Hogsoft's Pboost to load figures and item into Poser. It uses a Python script to achieve this. Also I want to have running an autoconform script to save to have to confirm each itemto a figure.
I have to stop the remote scripr from running before i run the auto conform script. Is there a way to have two python scripts running together?
Many Thanks
PhilC ( ) posted Tue, 10 July 2007 at 3:28 PM
It may be possible but the chance for conflict is very high.
alpha117 ( ) posted Tue, 10 July 2007 at 3:58 PM
Hi Phil
thanks, just tried it, and yep it works sometimes, then poser fulls over. :(
