Sat, Jan 25, 6:23 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 25 4:22 pm)
Subject: Removing (Unpacking?) full body morphs
cujoe_da_man ( ) posted Sat, 14 July 2007 at 1:24 AM ยท edited Sat, 25 January 2025 at 6:18 PM
I can assume the answer to this question is no, but I'll ask anyway:
I know all about creating full body morphs and all... but is there a way to change a full body morph back to its respective dials it was created from?
nruddock ( ) posted Sat, 14 July 2007 at 5:40 AM
Quote - I can assume the answer to this question is no, but I'll ask anyway:
For an FBM made using a modeller, then no.
The same goes for any FBM with a custom component that you don't have the OBJ source for, otherwise see below.
If your asking about and FBM made by turning dials and combining into a single morph, then it is theoretically possible.
You'd have to set up a progam to scan through a astronomical number of dial combinations and compare each with the FBM you want to decompose.
Not something you'd attempt without access to tremendous computing resources (similar kind of problem to protein folding).
Gareee ( ) posted Sat, 14 July 2007 at 10:33 AM
odds are,. those dials are just hidden.. in most cases, I don;t hide mine, but leave them in a PBM folder in each part... daz usually does the same thing, so they are available, but not readily accessible for new users to make mistakes with.
