Sat, Jan 11, 10:14 PM CST
Subject: Vue6.10 and Poser 6 SR3 Problem
StealthWorks ( ) posted Wed, 11 July 2007 at 6:32 PM · edited Sat, 11 January 2025 at 6:46 PM
Hi
I have the latest version of Vue6  Esprit and the latest service pack for Poser 6.
I have only just got around to trying the two together and fine that if I import a Poser object into Vue and then try to render I get the dreaded "Vue6.eon has stopped working" and I have to close the program. This error seems to occur just when Vue brings up the Post render options.
I have tried uninstalling and re-installing Vue 6 but the same thing happens i.e. I just can't render a scene that has an imported Poser figure in it.
I am running both applications under Vista ultimate and run them as "administrator"
Anyone have similar issues or suggestions on how to fix this?
Thanks
2ni ( ) posted Fri, 20 July 2007 at 1:23 PM
I have lots of bugs with the Vue 6 final and Poser 6 imports, Vue seems to be instable after Poser imports.
I 'm testing the last update but crash are still there.
Actually I'm still using the pre-release which is more stable.
e-on must release the 291551 for Esprit but don't know when.
StealthWorks ( ) posted Fri, 20 July 2007 at 1:29 PM
Actually, I think the issue to my problem was the graphics card. If I turn off both hardware and software OpenGL then a Poser6 import and render using Vue6 works fine. Question now is, is it the graphics card or Vue 6 that's not handling open GL in the standard way???
FYI, my graphics card is a NVIDIA FX1500 (installed on the Dell Precision M90 laptop)
zonkerman ( ) posted Fri, 20 July 2007 at 9:31 PM
I recently had a problem where Vue was locking up my whole PC.  However for my case, I found a solution.  Check out my thread below:
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2705718
